Schneider SW4048 connected to grid but says generator
latinhawk
Registered Users Posts: 36 ✭✭
My installation is being done in increments. So far The Inverter is connected to the grid and 3 48vdc battery banks. My problem is that I'm controlling it through a Combox but while it's allwsays been connected to the grid is shows as being connected to a Generator. I have found no way of changing this behavior. Any help will be greatly appreciated.
I just had the same issue. Go into System Devices and under your inverter you will see Associations, click on that and you will see AC Input Association (Generator), click on that and you will see where you can change it to Grid but the inverter must be in Standby, under Controls, to do this. Your power will shut down while in Standby so be prepared, make the change and save it then put the inverter back to Operating.
Thanks a lot. It worked like a charm.
