Solar installation for vertical water pump HELP!!!
2»
  • con2829
    con2829 Registered Users Posts: 20 ✭✭
    i called that company, they dont support the existing pump that is now installed and cemented
    Regarding running two motors from one controller... I think the answer is no.
    The VFD controller controls the speed of the pump based on available solar power and other inputs (on/off from tanks, back EMF from motor, run dry, etc.). Powering two separate motors would probably (at least) confuse the controller, and at worst run a pump dry or other issues.
    If the other system works--I probably would just leave it alone.
  • con2829
    BB. yah i thought about that too but i need confirmation from subject matter expert like you guys here. so im back to square one since i found out that my booster pump that i need to run is the wrong one, well for the system we need.
