Low power options for off grid Wi-Fi routers
We can get public internet via a high gain Ubiquiti Air Max antenna/receiver (receiver in the antenna uses 3W via power over ethernet) but will need to distribute the ethernet connection from this receiver about with a low power wi-fi router.
Any experience on what the lowest power consumption wi-fi routers there are out there now that would cover a 1500 sq ft place?
Goal is to use this setup to also connect a Combox for remote solar system monitoring.
- SolarIslander
Offgrid in cloudy PNW
Full Schneider system with 18 REC 420W panels, 100A-600V controller, XWPro, Insight Home, six Discover AES Rackmount 5kW batteries, Slimline enclosure, Lynk II, AGS, H650, H2200, H3000 (Propane conversion on Victron AutoTrans with Gen Line 2 wire AGS on AC1), Kubota 4500, Onan 7500 (on second AGS and AC2).
Just found the nice link below to a spreadsheet type page of wi-fi router power consumption. Values range from 0.8 W and up:
http://www.tpcdb.com/list.php?type=11
The lowest values of 0.8 Watts was for a USB powered travel router, likely not going to cover much area.Offgrid in cloudy PNW
The Apple Airport Express looks like a good combination of coverage vs power draw but other sites say that the current model draws 10-12 Watts despite a lower rating of about 3 Watts for the older MC414 model in the link above.
- 234 Forum & Website
