Canadian Solar inverter Modbus connection
jwrgorman
Registered Users Posts: 22 ✭✭
Hi,
Has anyone made a connection using RS-485 to a Canadian Solar inverter using Modbus RTU or TCP?
Thanks, John
Thanks, John
John Gorman / SolarNetwork Foundation
e:john@solarnetwork.net
I heard they make a 3 phase grid inverter? A bit out of the scope of this forum."we go where power lines don't" Sierra Nevada mountain area
OK thanks Dave, I did see some folks talking about modbus for other inverters in this form, so I thought I'd ask.John Gorman / SolarNetwork Foundation
e:john@solarnetwork.net -
If you e-mail me, I work with a bunch of solar wrenches that do commercial also. I can ask there."we go where power lines don't" Sierra Nevada mountain area
Thanks Dave, will do!John Gorman / SolarNetwork Foundation
I am just testing a Rika RK200-03 Pyranometer, looking good so far. You can use a SolarNode (running on a Raspberry Pi) to acquire the data from it over Modbus RTU, using a USB-to-RS485 adapter. We'll test it out but looks like it should help correlate array performance with a standard watts per m^2 and watt-hours per m^2 set of numbers.
