Any hands-on experience with Relion LiFePO4 batteries?
Marc Kurth
Solar Expert Posts: 1,191 ✭✭✭✭
Some talented engineering folks that I know in the battery industry have gone to work for them. I am hearing very goods things about the products and the people standing behind it. Applications in the field are performing as promised.
The product is heavily slanted toward being a drop-in replacement in common BCI sizes U1 through 8D. They also have a line of 24v packs up to 100ah and 48v packs up to 300ah. BMS/Cell balancing is built in.
Marc
Marc
I recently replaced my (6) - 6 volt deep cycle batteries in the 5th wheel in Oct/2017 with One Relion 12 volt-300 AHbattery. Two months in, so far I'm very impressed. The RV has 4 slide rooms that open and close up to 42 inches.The Flooded batteries had to be fully charged in order for the Electric/Hydraulic system to work efficiently. The RelionBattery is usually never less than 13.2V so the Slide system seems to effortlessly open and retract, regardless of whatSOC the battery is in...Also with the Lead Acid batteries, the RV 12V Led Lights tended to be less bright as the systemvoltage dropped after sunset and during the night to 12.8, 12.7 and considerably at 12.6 volts. With the Relion battery the Lights have never dimmed so much as a hair all evening long, but again the voltage has never gone less than 13.1 volts...Also when I'm running down the road towing the trailer at night, there is no dimming of the exterior running lights (16 of them) when I back off on the accelerator with flooded batteries I normally see some dimming! This is all a function ofsystem voltage remaining much more stable and constant during discharge.Another factor for the RV is that 6 flooded batteries and associated 2(00) cabling required, added hundreds of poundsof weight, whereas this 300AH Relion battery is only 82 lbs!..Maintenance wise...we all know the work involved incleaning battery terminal connections and cable ends, as well as filling cells with water. There is none of that necessarywith the Relion battery. As I get a chance to monitor the charging characteristics of the Relion battery, I'm very impressed with the speed at which the battery gets to Absorb and subsequently Float mode...Seems to me to be in theorder of at least 300 to 400 per cent faster! That translates to much more usable up time! If all these advantages don'tsell you on this technology, possibly this last advantage might...My SOC seldom goes below 80%...with the Floodedbatteries, best case scenario is about 5-7 years before replacement...Relion Data indicates at 30% DOD, one could expect to possibly see as many as 10,000 cycles (27 yrs) assuming one cycle a day..at 25 deg C of course.Even pushing the battery to 50% DOD is supposed to yield approx 7000 cycles.This factor alone prompted me to jump on the technology even at the steep price of 300% more than flooded...I may add another battery at some point down the road if I feel this technology has proven itself. With each batteryhaving it's own BMS onboard, that can be done with no disadvantage, whereas with flooded designs, all the batteriesneed to be changed at the same time or the older ones will bring down the new ones...It took some time and forethought to jump in on the Relion because of the initial cost, but two months in so far theadvantages have made me wonder why I didn't do it sooner!
Marc,
The last time I looked they were like Simplyphi but larger capacities for an offgrid home. They both lack the one thing that would make me interested for a home at this price range. There are not any coms for Soc internal with the BMS. Maybe I am wrong about this latest version? I hope so.
Are you done cutting trees from Harvey?"we go where power lines don't" Sierra Nevada mountain area
