Is a Conext XW+ a drop in replacement for an older Xantrex XW?
twistedtree
Solar Expert Posts: 135 ✭✭✭
My 10 year old XW6048 failed with an F69 (can't sync) error. It's a single system, no grid, so nothing to sync to. I'm trying to confirm that a Conext XW+ 5548 is physically a drop in replacement with the XW breaker box and conduit boxes, and that the XW+ is compatible with all my other XW gear (SCP, AGS, MPPT60, Combox).
Definitely! Yes! Is it inverting still?"we go where power lines don't" Sierra Nevada mountain area
No, it's not inverting. There is no power on the campus either. Deadninverter, I'm afraid
Ouch! You have surge protection? I like your plan, buy a 5548+ and get that one repaired for a spare or sell it.
Where or what is "the campus"?"we go where power lines don't" Sierra Nevada mountain area
Campus is xanbus after autocorrect get through with it
A defect in the Inverter will take down xanbus as it is the source unless the mppt-80's are used. Good Luck!"we go where power lines don't" Sierra Nevada mountain area
I picked up a new XW+6848 this afternoon and got it installed. We are now back in the 20th century. I picked the 68 over the 55 not because I need more power (I don't), but I definitely want more charge current, and the 6848 gives me 140A vs 100A from the old 6048.
I'll probably try to fix the 6048 and keep it as a spare, or use it somewhere else.
