Found Solar Part Thingy
DazedandConfused
Registered Users Posts: 2 ✭
Hello!
I was running along gloriously in the wilderness when I came across this. Seems like the right place to inquire so may I ask: What is it and how much is it worth? If I get a good answer I could track down the owner maybe. Thanks!
A circuit board from a charge controller. Probably worthless. Definitely burnt out, you can see the burned areas. It may have a couple working components if you are an electrical hobbyist, but if you were, you would have known what it is.
It was probably thrown out and picked up by kids that then lost interest and dropped it again. -
It is probably similar to this unit:
https://www.renogy.com/renogy-20-amp-pwm-duo-battery-solar-charge-controller/
Maybe $70 new. Worth very little of no case and manual.
Might be worth something to the owner... But out of the enclosure on a trail, would be very questionable.
Here's some better pictures, it did not appear to be out for long as it was quite clean when I found it and lying on its back. I do fiddle with electronics but mostly arduino, solar electronics are not my thing. Could get some parts out of it though
5 1/2" -
Oh... BZ Products.
http://forum.solar-electric.com/discussion/1162/bz-controller
Toss it in the trash (or salvage for parts). Lots of issues. The unit you found was probably built around June of 2004. Not really worth much now (or then).
