Powering 12 volt fence energizer from 24 volt battery
mryimmers
Solar Expert Posts: 117 ✭✭✭
Hi, what would be the most efficient way to power a 12 volt electric fence energizer from a 24 volt battery? I have a fencer running to protect a bee hive and have to leave it unattended for a couple weeks at a time, I currently an leaving a small exeltech xp250 running with a battery tender 12v, 750mA charger to keep a regular sized car battery charged, which in turn powers the fencer. The fencer uses 500mA @ 12 volts.
I am thinking either a 24-12volt converter of some kind, or a small charge controller?? It would need to be able to input up to 30+ volts, but not much for amps. Thanks, HH
510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
How much does that fencer use in amp hrs in a day? the Parmac fencers I have seen have a tiny PV that keeps a charged battery 'up' for the whole Bee season up here... I am thinking a 5W panel should be in the ball park for 2 weeks load on the battery..
at 500mA @12 volts, I guess 12 amp hrs a day at 12 volts? I would like to run it off my 24v battery bank which is already there and not doing much most of the time anyway. I have just started using this fencer and don't really know how long it will run on the battery, but I have to go to work, and don't want to find out the hard way haha.510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
Hmm, 2 days = 1 amp x 48 Hrs so 48Ahr. 50% of 100 Ahr (avg car batt.) = 50 Ahrs so it should take~ 2 days to use 1/2 of an average car battery total capacity...
Something like this? Up to 40 Volts IN to 12 Volts OUT for $10.00
http://www.ebay.com/itm/24V-to-12V-DC-DC-Car-Power-Supply-Inverter-Converter-Conversion-Device-/382068953412?hash=item58f5159144:g:jIoAAOSwYIxX99Zm
If you're not big on building your own voltage regulator with a 3 pin LM317 (there used to be 3 pin non adjustable regulators not sure why I couldn't find one...)
or you could buy this module, Texas Instruments TPS74901EVM-210, from DigiKey
Rancher
sorry rancher, but that looks like Egyptian hieroglyphics to me, haha, I guess I'd best just get something like mvas pointed out, thanks guys!!510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
cow_rancher said:If you're not big on building your own voltage regulator with a 3 pin LM317 (there used to be 3 pin non adjustable regulators not sure why I couldn't find one...)
Rancher
I got this, works great http://www.ebay.com/itm/TRANSLECTRIC-SM2412-5-HEAVY-DUTY-VOLTAGE-CONVERTER-5A-AMP-18-50V-DC-TO-13-8Vdc/232021258432?ssPageName=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
- 228 Forum & Website
- 653 Solar Water Pumping
- 618 Discussion Forums/Café
