2 Magnum PT-100 controllers and 1 ME-ARC remote
fishbreath7491
Registered Users Posts: 1 ✭
Is there a way to use 1 Magnum ME-ARC remote to monitor 2 PT-100 Magnum controllers? My PT manual says stacking is not supported at this time but I was told that a special cable can connect the 2 controllers together into the inverter. I have my second controller coming in a week and a Magnum MS4024PAE inverter coming at the same time. There is no instruction from Magnum on how to connect the cable or allow the remote to control 2 controllers so I am a little confused as to how this is supposed to be done.
I just found this while searching the internet on the same question:
It appears to be a draft out of a "new" PT-100 manual as my manual does not contain it.
https://www.solar-electric.com/lib/wind-sun/Magnum_PT-100_stacking_installation.pdf
Lee
P.S. The link was located on this site: https://www.solar-electric.com/magnum-energy-pt-100-mppt-solar-charge-controller.html
