Water leak
abdula
Registered Users Posts: 1 ✭
I have a water leak from my RTU unit to the panel should o change the conduit and wire or wire putty it
Make sure you fix the leak first then allow for everything to dry thoroughly (several days) and make sure your conduits are all watertight. Then try restarting it.
What is an RTU?
Roof top (air handling) unit.
