48 cell 110 watt solar panel question
Skip
Registered Users Posts: 18 ✭✭
A few years ago I came into 2 Risen Energy SYP110S brand new for next to nothing, the specs for them are: max power 110 watts, open circuit voltage 29.20v, short circuit current 4.99 amps, 23.30 max output voltage, max output current 4.71 amps, I would like to use these panels to charge 2 - 12volt 105AH batteries connected in a 24vdc series. What would be the most effective way to use these panels to charge the batteries? charge controller, MPPT or PWM or 1 panel per battery or ???
24 - 250 watt poly panels, 6000 watt SolarCity H6 Hybrid Grid Tied Inverter Mohave County Az.
Cheap MPPT charge controller. You can get a cheap one (Renogy for example) for about $120 that will accept up to a 100V input and will charge a 24V battery.Skip said:A few years ago I came into 2 Risen Energy SYP110S brand new for next to nothing, the specs for them are: max power 110 watts, open circuit voltage 29.20v, short circuit current 4.99 amps, 23.30 max output voltage, max output current 4.71 amps, I would like to use these panels to charge 2 - 12volt 105AH batteries connected in a 24vdc series. What would be the most effective way to use these panels to charge the batteries? charge controller, MPPT or PWM or 1 panel per battery or ???
Thanks for the info Bill, I will be looking for an MPPT controller, oh 1 question, would it be wise to run the 2 panels in series plugged into the controller?
24 - 250 watt poly panels, 6000 watt SolarCity H6 Hybrid Grid Tied Inverter Mohave County Az. -
You have to connect the panels in series. The voltage isn't high enough to charge a 24v bank if wired in parallel.Off-grid.
Yes. 48 cells are not enough to charge a 24V system without putting two in series.Skip said:Thanks for the info Bill, I will be looking for an MPPT controller, oh 1 question, would it be wise to run the 2 panels in series plugged into the controller?
Thanks Estragon, I had thought that was the way to go.
You want the voltage as high as you can get it with what you have and that means series wiring.
I would also choose a MPPT charge controller over a PWM type.
- 230 Forum & Website
