Battery and power inverter grounding
klane
Registered Users Posts: 3 ✭
i currently have my ground hooked up to the neg terminal of my battery bank. Do I also need to hook the ground directly to the Neg on my power inverter as well or will the one conection suffice? I realize I need to ground the metal caseing for my power inverter to the ground but not sure as far as the inverter electrical system.
Thanks in advance!
Thanks in advance!
One negative to ground connection only.Off-grid.
Thanks for the info!
- 230 Forum & Website
