"Indoor-type" combiner box?
VolcanoSolar
Solar Expert Posts: 56 ✭
Is there a standard, indoor-type breaker panel that holds Outback type DC breakers?
Or, is there another brand of breaker that's rated for nominal 72 volts DC, that fits in any standard-type indoor breaker panel? (I see that the Square D breakers only go to 48 volts.)
I bought a Square D "QO" type mini panel, having read somewhere that it would hold the Outback breakers, but there's no similarity between the two.
What I'm doing is dropping my PV wires through a 1.5" conduit from the pitched roof down through an exterior wall, and it would sure be nice to just have a combiner box right there in the wall, but I can't seem to get there from here. I did buy an Outback outdoor-type combiner box, but I want to mount something IN the wall, not on it, and have the 1.5" conduit drop right into the top of it.
What I'm left with at the moment is a standard junction box in the wall (one that has a 1.5" knockout in the top), with flexible conduit then going from it to the Outback combiner box that's surface-mounted nearby on the wall.
Clunky... ...and no, I don't want a combiner box on the roof itself, not with it being a pitched roof and having frequent rain.
Thanks,
-Ted
Thanks,
-Ted
Re: "Indoor-type" combiner box?
It is not what you asked for, but just another option.
http://home.comcast.net/~n3qik/Site/Photos.html#1
It is a home made, very cheap and will/should meet code.
The gray things are din rail mountable fuse holders I got off eBay for about $ 2.00 ea. -
Hey! This would work nicely.
Any spec to them other than "din rail mountable fuse holders" ?
Thanks,
- Ted -
Here is another set on eBay:
http://cgi.ebay.com/Entrelec-Din-Rail-Mount-Fuse-Holders-w-Indicator-Lot-8_W0QQitemZ200068805570QQihZ010QQcategoryZ67000QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
I will look a one today for more detailed specs.
Update: unknown manufacture- 240Vac @ 6.3 A or 600Vac @ 6.3 A Max. My guess is 240V if leave in the indicator, 600V if cut it out like I did. They use the 5MM x 20MM fues.
Update 2: manufacture is ABB, part # 0115 661.21, rated 10A @ 240V. If you remove the indicator, they are good to 600V. -
The QO type breaker box can be modified with hand tools to accept some DC style breakers. Here a picture of mine.
http://grapesearch.com/images/solar3.jpg
http://grapesearch.com/images/combiner2.jpg
Regards Mike -
Mikeo
Looks nice, but I don't think it will pass inspection with wood inside the breaker box. -
Ultra High Molecular Weight Plastic might do the trick. Available form Lee Valley Tools etc
http://www.leevalley.com/hardware/page.aspx?c=1&p=32045&cat=3,43576,43581
ej
INSPECTIONS? That is something we don't have to deal with in Arkansas counties. Would it possibly pass an inspection at your location if the breakers were mounted on a piece of formed sheet metal? This wouldn't be too hard to accomplish with tin snips and a shop vise and some sheet metal.
Regards Mike -
mike,
if the + and - leads are going to posts secured on a metal base they may short out unless on something insulative. if your posts are of a type that are insulated as they were made that way then you can mount them straight as is. wood is insulative, but is prone to moisture and insect damage making a future short possible. now if you need an insulative mount, it was suggested to go with a plastic and i agree. something even like a piece of plexiglass may do. -
Re: "Indoor-type" combiner box?Would it possibly pass an inspection at your location if the breakers were mounted on a piece of formed sheet metal?
Regards Mike
Yes, that would work.
niel- mikeo is mounting the circuit breakers to metal. His pos. bar looks to be 1" above the mounting plane. -
Right, just the fact that it was modified voids the UL listing.
- 228 Forum & Website
- 653 Solar Water Pumping
- 618 Discussion Forums/Café
