I have a 36v wind turbine, a 48v Forklift battery bank and 3000w of solar panels.
StevieD
Registered Users Posts: 1 ✭
Welcome to the forum Stevie.
Forgetting the wind turbine for a moment... Can you tell us what is your basic equipement?- Amp*Hour (20 Hour rating) of your 48 volt battery (is this 2x 24 volt in series, do you have any parallel battery strings)?
- Charge Controller (do you have one yet)?
- Solar panels... What Vmp / Imp rating (Voltage max power / Current max power) and how many?
- What are you loads (AC inverter, how much AH or WH per day do you plan on using)?
- Do you have the battery bank on some sort of AC charger? Generally, if you let flooded cell batteries sit for > 1 month without charging, they will sulfate and die not too long after.
- Have you check the electrolyte levels in the cells? Do you have a Hydrometer to check specific gravity (what is the SG?)? Do you have a good volt meter to tell us what the resting voltage of the bank is?
- Do you have a backup charging source (AC mains or genset + AC Charger)? Again--Flooded cell lead acid batteries do not last for long if left sitting.
http://www.solarelectricityhandbook.com/solar-irradiance.htmlDublin
Measured in kWh/m2/day onto a solar panel set at a 37° angle from vertical:
Not really great sun... Below 3 hours per day gets difficult to have a cost effective solar array.Jan Feb Mar Apr May Jun 1.08
1.79
2.48
3.42
3.91
3.76
Jul Aug Sep Oct Nov Dec 3.70
3.42
2.93
2.06
1.42
0.94
For example, January with 1.08 hours a day of average sun will give you (very roughly):- 3,000 Watt array * 0.52 typical off grid system eff * 1.08 hours a day (Jan) = 1,685 Watt*Hours per day (January typical)
- 1,685 WH / 48 volts = ~35 AH @ 48 volts
I am not a big fan of wind turbines--But with the right equipment in the right place, they can work.
