Need some thoughts on Off Grid Tiny House equipment....
If you are going to buy a generator to run a stove heater element or microwave or large battery charger you don't need an inverter generator.
Inverter generators only save fuel over fixed speed counter parts at well under half load. At half load or more there is little to no fuel savings.Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
