Mastervolt?
nyarelathodep
Solar Expert Posts: 99 ✭✭
Aside from having a name that would feel right at home on the shelves of a Walmart or Tractor Supply (nearly didn't click on it because of the name, till I saw the list price), this thing looks incredible:
http://www.mastervolt.com/products/mass-sine-24v/mass-sine-24-2500-120v-60hz/
Anyone have any experience with these units? Dutch made (like the highly regarded Victron), 5 year standard warranty with a 48 hour replacement for defective units.
Quick stats:
2500w (5000 VA surge)
Pure sine
Input current (nominal load): 104a
No load: 5w
Standby: .6w
Peak eff: 93%
Pretty expensive for a stand alone 2500w inverter at around the $2000 mark, but those self consumption numbers seem exceptionally good, far better than anything else I've seen. Seems like the perfect, albeit costly, inverter for the small system that has a high surge application or two. Any thoughts?
Quick stats:
Pure sine
No load: 5w
Standby: .6w
Peak eff: 93%
too dang much
~1.5Kw PV in parallel
Morningstar MPPT-60 controllers (2) in parallel
3 Trojan tr-1275's in parallel 450ah total
Samlex 2,000 watt 12-volt inverter hardwired
- 230 Forum & Website
