How does one balance 5 12-volt batteries in parallel?
barny
barny Registered Users Posts: 8 ✭✭
I have 5 12-volt lead acid batteries I want to hook up in parallel to my solar panels. I want to hook them up in a balanced manner but although there is information for hooking up 4, nothing specifically for 5.  Here is what I have come up with:
Positive: 1-4, 2-3, 3 to inverter, 4-5
Negative: 1-3, 1-2, 2 to inverter, 3-5, 4-5
Am I doing this properly or is there another method?  Thanks, Mike
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,171 ✭✭✭✭✭
    edited October 2016 #2
    This will apply to 5 batteries. Use method #3 but read the entire page as to the reasons why.
    BB. Super Moderators, Administrators Posts: 33,712 admin
    This is for a 12 volt battery bank, correct?
  • barny
    The website littleharbor2 gave cannot be found, and yes, Bill, I am using 5, 12V lead acid batteries hooked up in parallel.
    A little garbage at the end of the link. Try this
    5x 12 volt batteries in parallel is not my favorite. But if have them, might as well try and see how it works for you (follow good wiring practices).
  • barny
    Thank you, littleharbor2.  I found the page and looked at method 3 as you advised. I have one question about this setup.  I understand that the cables have to be the same length,  but how does one connect them externally before running the cables to the inverter? Thanks in advance.
  • Aguarancher
    Aguarancher Solar Expert Posts: 315 ✭✭✭
    buss bars are the preferred method in an application like yours.
    https://www.solar-electric.com/catalogsearch/result/?q=BUSS+BAR
  • barny
    Thank you, Aguarancher.  For all the difference it will make, I may use method two.  In the explanation of method three, they recommend using it 'for 8 or more batteries'. Cheers.
  • barny
    Which buss bar would you recommend - 5 battery cables + and 5 - and the cable to the inverter for each.
  • Aguarancher
    personally I would use method #3. buss bars are usually made of aluminum or copper. what type you use depends on what type of battery cables you use. pre-made cables imo are the way to go. call the store and they can recommend what is best for your application.  i use copper buss bars.
  • Mountain Don
    edited October 2016 #11
    You can buy premade copper bar or plate ground.buss bars from Storm Power. They used to sell raw bar and plate stock to make your own I did that and used S/S fasteners. But I don't see the option to buy bar or plate stock anymore; just factpry made components.
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,190 ✭✭✭✭
    @Mountain Don - your link is missing the colon after http in your link:
    http://stormpowercomponents.com
    Marc
  • barny
    I have it figured out - thanks everyone for your help.
