A simple point in the right direction
Bah200018
Registered Users Posts: 4 ✭
Ok, I have 48 panels ranging in size and wattage, most are peak 17.85v all others close to this. It's a combined total of over 2kw and that's being VERY conservative. I have 66 sunsaver 6a12v charge controllers as well as 10 powersonic agm 100ah batteries. Now, all this is being placed in a outside utility room that's brick. I can parallel a couple panels together per single controller, but then I'm running many many wires through a now huge conduit, and trying to run that through a brick wall. If i parralell all the panels together, the amperage is over 150 at 16v, again. ..very conservative figures. But I would only have 2 wires to deal with. Can I then use a distribution block to run the charge controllers off of? Or will I fry the controller from top much power input?
Bah200018,
I have moved your first post to its own thread here:
http://forum.solar-electric.com/discussion/351242/bah20018-help-setting-up-new-off-solar-battery-system#latest
You can continue the discussion there.
