bus bar insulators
ws9876
Solar Expert Posts: 453 ✭✭✭
Hi ws..,
Assume that the SqD busbars that you might be wanting to use are either the long Neutral or Ground busbars.
Many folks use either the MidNite or Outback insulated busbars:
https://www.solar-electric.com/catalogsearch/result/?q=midnite+insulated+bus+barYou could even use the insulating ends from some of the above on a longer SqD bar.
Just one approach. FWIW, Vic
Off Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
- 230 Forum & Website
