Electric Fencer Power
mryimmers
Solar Expert Posts: 118 ✭✭✭
Hi, I have a 12 volt electric fencer that I would like to power off of my 24 volt battery bank.
Current at 13.6 volts is 470mA (6ish watts?) Being such a small load I was thinking of maybe just taking 12 volts right off the bank with alligator clips with an automotive fuse in the wire?
Is that enough of a load to cause a problem? Or should I look at a small charge controller or converter to hook to the battery bank?
Also regarding grounding, I've looked around a bit on line and it appears I should not use the same ground for this fencer as my solar system? Have not yet seen why though.
510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
Lightning can be a big issue with electric fences... the entire fence is a lightning antenna. I would build an entirely separate 12 volt system for the fencer... the systems should share nothing, not the battery, not the solar panels, not even a ground rod. Why risk your home power system for a 6 watt load?
This is to protect a bee hive, so maybe not as "out there" as an actual fence, but I see your point. Apparently these fencers will run for weeks on a regular sized 12 volt battery, so it shouldn't be too big a deal to go that route, thanks!!510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
these run all season, you should be able to cobble a similar setup together. a bit pricey though...
http://www.statelinetack.com/item/parmak-magnum-12-solar-pak-fencer/BXF56/?srccode=ADSLPH&gclid=CKXbvu6jxs4CFcSGaQodlMUKmA&kwid=19959388920x8767013268x210917748
I already have this fencer http://www.gallagherfence.net/products/b700 used for $50 bucks !! Just need a battery, and I will keep it separate from my cabin system. Thanks guys
510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen. -
The battery could be charged of the house/cabin system and then put back to the fencer.
Ya that's what I'll do, shouldn't have to charge it too often.
Thanks, vtmaps for pointing out the lightening aspect510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
- 230 Forum & Website
