Adding more panels
Thom
Thom Solar Expert Posts: 196 ✭✭✭
thinking of adding panels using a Brat charge controler. Would like another 200w . Would this work ok with my existing system? Could I EQ with both controllers?. Is this a dump plan ? My system is listed below
thanks Thom
Off grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator . Added 2@ 100w panel with a midnight brat
    BB. Super Moderators, Administrators Posts: 33,731 admin
    What is the Vmp of the 200 Watts of solar you want to add? Is this a 200 watt panel with Vmp~30 volts or a pair of ~100 Watt panels with Vmp~100 Volts? For a 12 volt system and PWM Brat, you would need Vmp~18 volt panels.
    For equalization, you probably only need to put the Rogue in Equalization mode... You only need around 5% rate of charge to equalize and your 430 Watt array should be enough.
  • Thom
    Yes I'm thinking 100w 18v panels . Could I use both to Eq ?
