Using Ebay "LiFePO4" Batteries For A Battery Bank
I recently found this ebay listing :http://www.ebay.com/itm/12V-60AH-LiFePO4-Batteries-6A-Charger-BMS-Electronics-Parts-Rechargeable-700W-/131808965156?hash=item1eb06d3224:g:i7IAAOSwcL5XMYue
And was wondering what you guys think about it, to me it look's like cheap li-ion batteries with "LiFePO4" printed on them.
But if they really are LiFePO4 batteries then there a really good deal.
  • oil pan 4
    Those puny wire look like they could only handle discharging about 20 amps continuously, if that.
  • bill von novak
    bill von novak Solar Expert Posts: 892 ✭✭✭✭
    Depends on what you are going to do with them, of course.  Three in series might make a good ebike battery.
    Here is the website for that battery setup (not sure if website is current or just an old one laying around):
    http://www.sun-ebike.com/
    edited June 2016 #5
    I am posting this for Karrak (we are having a random problem with long time posters getting stuck in the spam queue).
    Unless the inbuilt BMS in this battery is properly designed and built the lifespan of the battery can be significantly reduced regardless how good the individual LiFePO4 battery cells within the battery are. Read the following for more information.
    https://ka7oei.blogspot.com/2013/05/lithium-iron-phosphate-lifepo4.html
    If you have enough electronic knowledge I would look at getting the individual cells and making up your own BMS or getting a complete unit with inbuilt BMS from a reputable supplier who is prepared to give a decent warranty with the battery.<br><br>If you do get a complete unit, it is good to have external access to the individual cell voltages so you can check to see if the battery is keeping in balance.
    Simon
