Grape Solar panels
DConlyGuy
Registered Users Posts: 80 ✭✭
ive have bought 3 100 watt panels off ebay and they seem to be working ok. i was looking thru home depot web page and they have 100 watt grape solar panels for 124.99 with free shipping. this is about 20 buck more than you can get one off ebay for now i just wondering if the grape solar panels are worth spending he extra 20$ on?
600 watts of solar panels,Epever 30 mppt , 2 PWHR12500W4FR battery's in 24 volt setup
If you can exchange them at home depot if you get a bad one then totally worth the extra $20.
My 100 watt panel came from Home Depot and I'm pleased with it. It was worth the few $$ extra to me. If it had arrived damaged or if I had a problem it would've been easier to return it. Hope to order another one before fall comes as well
never even thought of the return part, it's nice to have a home depot only 4 miles away to return if it is bad600 watts of solar panels,Epever 30 mppt , 2 PWHR12500W4FR battery's in 24 volt setup
- 227 Forum & Website
- 618 Discussion Forums/Café
