Entrance Gate set up
MarkC
Solar Expert Posts: 212 ✭✭✭
Any concerns using the following panel with an inexpensive PWM 20 amp controller? The service is a 12 volt DC motor driving a hydraulic system to open and close an entrance gate a few time a day. Any recommendations for the best battery to use? Replacing the entire panel/battery system.
20 watts monocrystalline, 17.5 Vmp, 1.14 Imp
http://www.ebay.com/itm/New-20W-Solar-Panel-12V-20-Watt-Mono-for-Off-Grid-RV-Boat-Battery-Charge-Camping-/161884201303?hash=item25b10ce157:g:c9EAAOSwiwVWR2zw .
PWM CC is one of the cheap Chinese nominal 12 volt PWM controllers.
3850 watts - 14 - 275SW SolarWorld Panels, 4000 TL-US SMA Sunny Boy Grid tied inverter. 2760 Watts - 8 - 345XL Solar World Panels, 3000 TL-US SMA Sunny Boy GT inverter. 3000 watts SMA/SPS power. PV "switchable" to MidNite Classic 250ks based charging of Golf cart + spare battery array of 8 - 155 AH 12V Trojans with an APC SMT3000 - 48 volt DC=>120 Volt AC inverter for emergency off-grid. Also, "PriUPS" backup generator with APC SURT6000/SURT003 => 192 volt DC/240 volt split phase AC inverter.
At 5% to 10% rate of charge, the typical 12 volt deep cycle battery would be:
- 1.14 Amps / 0.05 = 23 Amp*Hour maximum
- 1.14 Amps / 0.10 = 11 Amp*Hour minimum
Deep Cycle flooded cell will require you to check water level every 1-2 months typically.
Does your charger have an AGM/Sealed battery charging option (typically 14.4 volts max for AGM, and 14.2 volts max for GEL).
Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset - 1.14 Amps / 0.05 = 23 Amp*Hour maximum
It's my Son's gate. He decided a while back to "buy" a warranty and replace the auto style battery that he bought, if it goes bad. I've told him that he should eventually go with a ~ 30 AH AGM (I have several from my UPS dealings). Seems we are in agreement. I'm not sure about a specific AGM setting, but I believe I can modify the float voltage. I'll check.
The "idle" current is less than 10 ma, but I do wonder if the charging losses are significant with only a 20 watt panel.3850 watts - 14 - 275SW SolarWorld Panels, 4000 TL-US SMA Sunny Boy Grid tied inverter. 2760 Watts - 8 - 345XL Solar World Panels, 3000 TL-US SMA Sunny Boy GT inverter. 3000 watts SMA/SPS power. PV "switchable" to MidNite Classic 250ks based charging of Golf cart + spare battery array of 8 - 155 AH 12V Trojans with an APC SMT3000 - 48 volt DC=>120 Volt AC inverter for emergency off-grid. Also, "PriUPS" backup generator with APC SURT6000/SURT003 => 192 volt DC/240 volt split phase AC inverter. -
Roughly:
- 0.010 amps * 12 volts * 24 hours per day = 2.88 Watt*Hours per day
- 20 Watts * 0.61 DC system derating * 4.0 hours of sun (average ~9 months a year) = 42 Watt*Hours per day (rough typical charging non-winter time)
- 4 amps * 12 volts * 30 seconds * 1/3,600 seconds per hour * 5 times a day = 2 Watt*Hours per day
- 230 Forum & Website
