12 VDC systems 1000 Watts / 24 VDC systems 2000 Watts / 48 VDC systems 4000 Watts
GreenerPower
Solar Expert Posts: 264 ✭✭✭✭✭✭
I wonder where this "12 VDC systems 1000 Watts / 24 VDC systems 2000 Watts / 48 VDC systems 4000 Watts / 60 VDC Systems 5000 Watts" STC NEC spec is comming from. This seems to refer only from Outback charge controllers spec and not other CC vendors. I looked though my NEC book and any other references to NEC regarding PV and still couldn't find any. Curious what the basis for these limitations.
GP
GP
Re: 12 VDC systems 1000 Watts / 24 VDC systems 2000 Watts / 48 VDC systems 4000 Watts
GP,
Continuing our earlier discussion from the OutBack forum, I suspect the 125% difference between the FlexMax 80's "maximum solar array" specs and its "NEC recommended solar array specs" is derived from 690.8(A).
I disagree that these derated specs don't seem to apply to other CC's. The manuals for the Apollo T-80 (page 7), the Blue Sky 6024 (page 13), the Morningstar TriStar (page 1), the OutBack MX60 (page 82), and the Xantrex XW (page 2-2) all include derating discussions.
Regards,
Jim / crewzer -
Jim, I agree with you on the 125% of the Isc STC. I was thinking if I have a 48V system, what limits me from having only 4000W STC worth of PV. Sure I can have 8000W worth of PV if I size the wiring and circuit breakers properly. I think i get it now, I missed the keyword "name-plate". This is for a single FLEXmax80 device. It can handle that much PV wattage. The NEC reference just threw me off to think this is for the whole 12V/24V or 48V system. Thanks,
GP -
:cool:
Regards,
Jim / crewzer -
There may also be UL1741 specific limitations that make this stuff somewhat harder to define.
boB -
UL1741 did cross my mind but then I thought this was just the CC and for off-grid system, UL1741 doesn't apply. So my train of thoughts went for more generic case rather than grid-tie. -
UL1741 applies to both on grid and off grid, as does NEC. All that fire prevention and shock hazard stuff etc...
I seem to remember that there used to be a state or two where UL wasn't absolutely required, but I don't know if
that's still true or not.
boB
- 234 Forum & Website
