30A MPPT Charge Controller - SRNE - MT2430
jped
Registered Users Posts: 8 ✭✭
Does anyone have any info/experience with the following controller. I can't find much about it or if it is a good controller or not.
http://www.srnesolar.com/pro/mt2430.html
http://www.pscsolaruk.com/charge-controllers/XANTRA-12V-24V-AUTO-30A-MPPT-CHARGE-CONTROLLER?sort=p.price&order=ASC
The SME does not appear to have any programmable set points for charging (bulk, absorb, float). If you use flooded cell deep cycle batteries, the default set points are a little bit low--But they can work if you are not deeply cycling the battery.
How well they are designed/put together--I have no idea.
Sounds like I should stick with Morningstar or better known brands.
You are on the other side of the world from me (I guess)--I know that US products are probably not cheap other there.
The cost of experimenting may be worth a try--Or if you have a good local dealer/other solar users in your region, they may have some local/China direct brands that will work better.
