Hawaii & Solar or, more bad news
Dive Brief:
- Hawaii's decision last year to end its retail rate net metering program has led to a contraction in the solar industry, and observers say more job losses are on the way, the Associated Press reports.
- Currently, installers appear to be working through a backlog of approved solar projects and those still in the queue which will still receive the ful retail rate for the energy sent back to the grid. But once those projects are completed, solar companies appear poised to pack up shop or shift to more lucrative energy installations.
- A Hawaii Circuit Court in January upheld state regulators' decision to replace the program. The Alliance for Solar Choice had filed a lawsuit, alleging the changes were made with insufficient notice or review, but the judge upheld the state's decision.
Dive Insight:
Hawaii's solar policy changes are having a predictable effect: More than half of install companies on the island have reduced or plan to reduce their workforce, the result of lower solar rates making rooftop systems less attractive.
According to the AP, 10 of Hawaii's 16 solar companies have indicated they will downsize, and its possible the trend will accelerate as solar projects still being considered for the full retail rate are approved and completed.
“Frankly, the industry is living off of these approvals,” Jae Kwak, chief financial officer for Haleakala Solar, told The Times. “As those get built, there is going to be more hardships. There is going to be more job losses.”
Earlier this month, Hawaiian Electric Co. said it was still reviewing 1,175 applications.
According to the Hawiia Public Utilities Commission, the net metering program was capped to protect the stability of the state's grid against Hawaii's uniquely high penetration of distributed solar. From here out, new rooftop solar users will have to choose from two other payback schemes.
The self-supply option – a non-export option – allows a limited amount of inadvertent energy exportation to the grid without any compensation. Residential customers who choose this option will have a minimum bill of $25, while small commercial customers will have a $50 minimum bill.
The grid-supply option will open the door for exporting excess energy to the grid for credits against customer bills so long as the exports benefit the electric system. While similar to net metering, this option does not credit customers at the retail rate. Instead, the new grid-supply programs credits customers at a fixed rate between $0.15/kWh to $0.28/kWh, depending on the island on which they are located.
Net metered systems have increased by over 60 times the cap established by the initial 1996 legislation that set up NEM for Hawaiian Electric customers, and program capacity now runs from 30% to more than half of system peak load, depending on the island. Nearly 20% of all customers of the Oahu and Maui subsidiary utilities have net metered distributed generation.
While some solar installation companies are downsizing or looking to move employees into other markets, others are working to remain afloat in the new marketspace. “They have just plain given up on selling,” Rolf Christ, CEO of R&R Solar Supply, told AP. “They just are installing what got approved. Some are leaving the state. Some are moving from (photovoltaic systems) to lighting contracting.”
Recommended Reading
AP via Washington Times: Solar companies struggle with end to incentive program
Once someone starts detonating EMP devices and taking down the power grids around the world, solar will be the only viable option for reliable electricity.
Only if you've got a second (,third...) set of electronics stored in a metal box.....Northern NM, 624 watts PV, The Kid CC, GC-2 batteries @ 24 VDC, Outback VFX3524M
Those Sears metal sheds are great if you ground them! Maybe an SPD or 2. Cheers Don!"we go where power lines don't" Sierra Nevada mountain area
That's good to know. I've got one of those metal sheds and maybe I'll ground it since my riding mower is in there. At least I can mow grass lolDave Angelini said:Those Sears metal sheds are great if you ground them! Maybe an SPD or 2. Cheers Don! -
The really sad part about Hawaii is they have mandated 100% renewable by 2022 I think and they won't replace the Diesel or Bunker oil generators with natural gas. They really have a challenge that most doubt is achievable. Better get use to not having air conditioning."we go where power lines don't" Sierra Nevada mountain area
Cant they use some old craters or something for pumped water storage? Efficiency is something like 50% but still a whole lot cheaper than diesel. And thats today, tomorow when oil goes back up... no brainer.
I think the feds just voted a few months ago to extend the 30% tax incentives for a few more years on a declining scale as we get nearer 2022? Does anyone know if the State of Hawaii is also following suit? there is a 35% tax incentive from the State right now that is good through the end of this year, 2016, but I believe that's currently slated to die on the vine next year.
Hawaii is a state in the USA. Of course the federal laws for the Photovoltaic and Domestic hot water 30% incentives apply until 2019."we go where power lines don't" Sierra Nevada mountain area
Thanks Dave. No, the federal incentive is 30%. Hawaii has another 35% on top of that, so the total tax offset becomes 65% when you add them if you put the system into service in 2016 (to a max of $5k per year per system, but if you have excess credits they can carry forward to your next tax year). Now, the feds have said OK to several more years of their 30%... but I don't know if Hawaii has signaled their continuation of their 35% into the same period.
thanks,
walt
In most states, you have to be grid connected to get their state credits! So, are you not offgrid? Don's link should tell you all you need to know."we go where power lines don't" Sierra Nevada mountain area
A lot of what happened back then pushed companies here to rethink how they design systems, especially with storage and self-supply becoming the norm. These days, the installers who focus on long-term reliability rather than retail NEM rates are the ones still doing well.
If you're looking at how the market evolved, some hilo solar companies like BlueSky Hawaiʻi have shifted toward smarter hybrid and storage-first setups that don’t rely as heavily on old incentive structures. They’ve actually managed to stay strong by focusing on customer-specific engineering instead of volume sales.
Exploring renewable energy for remote travel & eco-tourism.
