connecting 2 12v sources to one 12v battery
jrroper
Registered Users Posts: 2 ✭
Hi, i have a wind generator and 2 solar panels going thru a hybrid controler, and a solar panel going thru a solar charge controler, can or how do i connect the 2 12 v outputs to one set of batteries, the reason for 2 charge controlers is the wind/solar has a limit of 600 watts, and the one solar panel i plan to increase the number of solar panels, i want to try to keep from having 2 sets of batteries, thanks jrroper
In general, you run the solar panels through a "series" type PWM or MPPT type solar charge controller. The controller simply "turns on or turns off" the solar panels as needed (of course, there are more details).
A typical wind turbine system would connect the output of the Wind turbine Alternator=>Rectifier=>Battery bank. And you have a second "shunt" type charge controller that turns on when the battery voltage gets too high and dumps power to a resistor bank--The resistors dump waste heat into the air until the winds die down or the loads increase.
There are lots of other ways of doing this--So if you have a link to the hybrid charge controller--That would be a big help.
Bill, thanks, i think i understand what you are saying, as it is now, i have the 400 watt wind turbine and 2 100 solar panel going thru a hybrid controller, i have right now 1 100 watt solar panel going thru a seperate controller, what i am concerned about is can i connect the battery output of both controller to the same battery, i want to increase the number of solar panels going thru the solar charge controller but i would like to stay away from have 2 sets of batteries
