need more info on making a BTS from earlier info
2nd system: 24V system with 4 X 310W panels, Midnite Solar combiner box, Midnite Solar mini-dc disconnect, Midnite Solar Classic 200, Cotek 1500W pure sine inverter, Trojan 125 batteries (8 available but "currently" using 4)
The the air in the tube will slow down the responsiveness, but it won't be a problem because changes in battery temperature occur very slowly... the temp probe will be able to keep up with the changes.
elesaver, what sensor did you decide to use?
Paul
in Georgia
Paul
in Georgia
System 1: PV- 410w Evergreen, Mppt- Blue Sky Solar Boost, Batt - 225ah Deka AGM, 12v led house lighting,
System 2: PV- 215w Kyocera, PWM - Morningstar PS30, Batt- 225ah Deka GC's, 12v led house lighting, Dankoff 12v water pump,
System 3: PV- 1.5kw Kyocera, Grundfos 11 SQF well pump, 3000 gal above ground water storage, dom water & irrigation,
System 4: PV- 6.1kw Kyocera, Mppt- Outback FM80-2ea, Inverter- Outback FX3648-2ea, Batt- 804ah GB traction, Grundfos BMQE booster pump 240v, Mitsibushi mini-splits 240v, 18k and 15k -
vtMaps, thanks for the info about air and temperature. That helps a lot.
Paul, I have two choices: I bought a thermistor from mouser electronics as mentioned by someone in another thread. Then if I can attach those leads to a phone wire and place the sensor into the tube, it'll be good. Then I can plug the other end into the charge controller so that the info is relayed. I am going to try this first.
As a backup and probably the better choice is to "dismantle" the Midnite Solar BTS and place its sensor into the tube. The other end, of course, would go to the cc. I hate to tear up the Midnite Solar BTS if I don't have to simply because it costs a bit. Plus, there's always that fun in "doing it yourself." Somehow that has always been my bent. We'll see.
1st system: 24Vsystem with 8 X 300W panels, Midnite Solar combiner box, Midnite Solar mini-dc disconnect, Midnite Solar Classic 150, Outback VFX 3524 with mate, 2 X 12V fforklift batteries in series 938 aH, (Outback PSX transformer, Honda EU3000is...not currently hooked up but available if/when needed)
2nd system: 24V system with 4 X 310W panels, Midnite Solar combiner box, Midnite Solar mini-dc disconnect, Midnite Solar Classic 200, Cotek 1500W pure sine inverter, Trojan 125 batteries (8 available but "currently" using 4) -
Hi elesaver,
Posted the following in the Building a RTS Battery Cap Thread, but just for you and your Classic you probably will want to confirm that your Thermistor has the 3988K Curve:
An Update on the NTC Thermistor Part Number at Mouser:
Just ran a Resistance vs displayed temperature for a Classic CC BTS. The following part number appears to be a very good Curve Fit:This part has a ' 3988K ' curve and is still 10 K ohms at 25 C.
Have not run the curve for the Outback RTS, BUT, it might well need a different curve 10 K NTC Thermistor.
Good Luck, Vic
Vic said:Have not run the curve for the Outback RTS, BUT, it might well need a different curve 10 K NTC Thermistor.
Hi vtmaps,
Yes, recall seeing that said by boB, but, just trying to be a bit cautious, AND, after looking at the difference between one Classic BTS verses one OB MX-60 RTS, on the same battery at the same time, was not so certain.
Certainly, both the OB AND MN Sensors appear to be 10 K NTC Thermistors.
Just did not have the time to run the OB RTS last night, and would hate to suggest that someone buy an incorrect Thermistor for the application.
As an aside, it is more than a bit surprising that after asking twice on the OB Forum that OB Tech chose to NOT reply, to questions for the RTS Table, and weather there were any differences between any of the OB RTSes. These ALL must be Trade SECRETS!!
Thanks again for that RTS Table. There is a strong suggestion that this is also the Table for the MX-60 RTS, at the very least. YES, it would seem to be an obvious assumption that there would only be ONE RTS for one company's products, but was just trying to be a bit careful about assumptions.
More Later, Thanks, Vic
Hi vtmaps,Well, I am very happy that you did grab that file, while it WAS there, but while that file does have size, it displays as a null file on my .pdf reader.
The other links that I found were also broken/non-functional, but this file may require a different reader.
Just ran an OB MX-60 resistance vs Count value, using the Table that you provided earlier. The resolution of the MX's A/D limits the MX to a nominal one-ish degree C resolution. But, it appears that the OB RTS, as supplied 11 years ago with the MX-60 is fairly close to the Curve of the 10 K NTC, Linked above.
The Classics, with their tenth-degree C temperature resolution make curve checking much easier.
So - Thank You again! Vic
Is this the right file? (attached PDF):
And, here is the Outback Forum count to temperature conversion info:
http://www.outbackpower.com/forum/viewtopic.php?p=14411#14411
Thanks for all of this info. These things are far "above my pay grade," so to speak. But, the seat of my pants has permanent wings since I continue to fly with those wings quite frequently. I'll try to read and understand. I guess what you're trying to tell me is that this thermistor will work, even though that fact was unbeknownst to me.
The goal, of course, is to get some good temperature information about the electrolyte. We'll see what happens.
BB. said:Is this the right file? (attached PDF):
Hi Bill,YES! That IS the File that vtmaps sent, and reposted. Thanks!
And, elesaver, I believe that you now have a 10 K NTC Thermistor. If so, was asking that you confirm the spec for that device.
If the Thermistor IS from Mouser, and is a 10 K Ohm NTC TDK Epcos 60 milliwatt device, then wanted you to try to confirm that the spec on the device matched the curve 3988K. There should be the exact part number on your Invoice. If the part number on the invoice matches the part number for the link in this Thread, then you should have a device that matches the MidNite sensor very well.
This should be the exact Mouser P/N for the 'correct' device, if you bought the noted device from Mouser:
871-B57871S103F1That was all ... Thank you,
Vic
elesaver said:Thanks for all of this info. These things are far "above my pay grade," so to speak. But, the seat of my pants has permanent wings since I continue to fly with those wings quite frequently. I'll try to read and understand. I guess what you're trying to tell me is that this thermistor will work, even though that fact was unbeknownst to me.
I would think your goal is to make sure the corrected voltage is accurate at various temperatures. I tried to attach a file from Xantrex that pretty much covers the voltages one should see. Shooting the terminal with a decent electronic temp gage is also a way to check this.
Vic said:BB. said:Is this the right file? (attached PDF):
Vic
It's all such a wonderful experience and to think that I can run parts of my household on the power from the sun! It's just a delight. Thank you for all your help! It is deeply appreciated. You make learning is truly a pleasure.
Hi elesaver,
Since the Thermistor that you purchased is the one that matches, well, the one used in the Classic and OB BTS/RTSes, you should not need to worry about the exact details of the curve. The Thermistor manufacturer has done that for you!
The Chart that Dave posted is simply the Temperature Compensation values for different temperatures with different battery voltages.
The Classic will show you the voltage settings that you have, AND, the Compensated voltages for the battery Temperature, which the Classic will also display ... so the Classic tells you all you need to know, without the table.
At some point, it would be good for you to compare the temperature reading of your BTS (in the Classic's Temp menu), with a temperature reading of the electrolyte. This electrolyte temperature could be read, with a glass thermometer, if you have one available.
So, Good Luck with the project. And, please let us know how things are going. Vic
- 616 Discussion Forums/Café
