Would a small DIY turbine benefit from MPPT?
JoshK
Solar Expert Posts: 232 ✭✭
I am building a small wind turbine for fun. It's 36" on this first try. I want it to work in low winds. The motor I chose to use as a generator is rated at 120VDC, 60W. I highly doubt I will be getting up to the rated RPM in the low winds though.
What I am wondering tonight is should I consider a MPPT charge controller? Or would the extra load imposed just reduce my RPM to the degree where it's the same as not using MPPT?
I may be building more turbines and feeding the same charge controller. Maybe.
There is no "energy" in low speed wind (less than ~10 MPH or so). There is no way to harvest substantially more power in poor (or turbulent) wind conditions with an MPPT controller.
But, yes, a properly designed wind turbine system may see a 2-3x increase in harvested energy vs a standard Alternator->Rectifier->Battery Bank connection. That was Midnite's test results (as I recall reading here a few years ago) when they brought out their integrated wind controller-system.
My idea of low wind is around 12mph, which is about half the MPH they usually rate tubines at. And 1/2 the wind equates to 1/8th the power I think. So I should get what I need from 36". I will know soon.
Any suggestions on a good MPPT controller for this low wattage system? -
I don't know enough about the MPPT systems to say much.
Hopefully somebody else can help.
-bill
Alright, thanks for the info Bill.
We had a 12mph wind last night to test it with, it was a full success!
If anyone knows a cheap MPPT controller, let me know. -
please define "Cheap" ???
The least expensive MPPT option that can handle 120v/60W. I don't know what that price point is.
well I will let you decide if these are in your price range all from our sponsor, some examples...
Midnite Kid
http://www.solar-electric.com/midnite-solar-kid-mppt-solar-charge-controller-black.html
Morning Star, several models starting at $225
http://www.solar-electric.com/inverters-controllers-accessories/chco/mochco/admpchco.html
the 120 V DC (?) is a problem... did you mean 12V, I assumed you did
The first link gives error 404, the second one is good. Still more power handling than I need. And a little skimpy on the volts. I really did mean up to 120VDC. I chose to high voltage as a way to efficiently transport power over a decent distance with inexpensive wire. It would take a heck of a wind to get full voltage though. I hope it never reaches those speeds. 75VDC open circuit is probably the most RPMs I will allow.
- 228 Forum & Website
- 653 Solar Water Pumping
- 618 Discussion Forums/Café
