[need help] pv output
corazon
corazon Registered Users Posts: 2
halo, i'm new on this technology, i want to ask is it possible to find the output of pv module if its not connected to load?
according to Pmax=Vm.Im or Pmax=Voc.Isc.FF
from multimeter i can get the value of Voc and Isc but i'm stuck how to find the value of Vm and Im
please help me, thanks before :D
  • Shawn-H
    Shawn-H Solar Expert Posts: 107 ✭✭
    I need to know more about the components and what you have charge controllers load diversion devices things like that
    100% Off-grid in the White Mountains of Arizona. 36 Kyocera 265w mounted on four DPW 9 module pole top mounts, midnite solar combiners, breakers, & lightning arresters, 1 midnight solar classic 150, & 3 classic 150 lights, 3 x 1574 AH GB Industries forklift batteries total of 4722 AH @24v. Feeding a Outback power systems FW500 with 2 x VFX 3624, with the x240. 2 Honda EU3000is gensets with the 240 combiner and control box running LP, and 1 Honda EU2000is Gas.
    System #2 is a off grid water system @ 1590w (6 Kyocera 265's) on a 6 module DPW top of pole mount. Feeding a Granfas deep well pump and pump controller at 580 feet. 2 x 2800 gallon above ground poly storage tanks, and 1 x 1200 gallon underground  cistern and a Granfas 24v booster pump feeding a 90 gallon carbon fiber pressure tank.
    Vag woodstove for heat.
    Follow our journey at
    https://www.facebook.com/ShawnpHarvey
  • inetdog
    edited November 2015 #3
    You cannot reliably tell the output of a PV module (cell or panel?) without a variable load. The only things you can measure are Voc and Isc. It is true that IF you know the fudge factor (FF?) for a particular cell design you can estimate the output as Voc x Isc x FF.
    As a rule of thumb for crystalline silicon cells Vmp is about 80% of Voc. The ratio between Isc and Imp will vary more widely.
    To actually measure Vmp and Imp you need to attach a variable resistance load and tune it to the Maximum Power Point before measuring. Or hook it up to an MPPT inverter or to a CC charging in Bulk mode into a depleted battery bank. And the whole time you need to use a calibrated reference light source or have the panels facing directly toward the noon sun on a clear day. Even in the latter case the panel temperature will be an uncontrolled variable.
    SMA SB 3000, old BP panels.
  • corazon
    thanks a lot @inetdog , i nearly understand,  so if  my panel not conected to any load (inverter, solar charge controller or variable resistance load), and i only measurimg the Voc and Isc with multimeter, i cant calculate Pout of my pv module (panel) right?
    btw what is the difference between Pmp and Pout?
  • oil pan 4
    If you are only working with Voc times Isc you will get an unrealistic amount of wattage.
    Dave Angelini Solar Expert Posts: 7,091 ✭✭✭✭✭✭
    You should get a pretty close reading of power out with Isc.  Close enough for government work...
  • corazon
    from equation 5.12, i need value of Imp and Vmp to get the FF (fill factor) value.
    if i cant measure the Vmp or Imp since my PV panel not connected to any load, can i use eq 5.13 to get the FF?
    thanks before
