playing around with some ideas
rcmatt007
Registered Users Posts: 7 ✭
I have been thinking of adding a back up system to run a few things in case of an outage, but also wiring it into an small "add on room" to provide some heating and cooling so the system will not be sitting there doing nothing. In Oklahoma we get a lot of sun, but have weather related outages
I have decent experience with construction and wiring, but this whole solar thing is new. I am also looking at ways to get the parts I need without paying a fortune for shipping (picking up at home depot and northern tool e.g.). I also understand that by running things in series I can eliminate a lot of redundant wires and keep the amperage down and reduce loss.
Here is what I am looking at:
4 grape solar 265W panels run in series which would give me approximately 124 volts (30.96 each) @ 8.56 AMPS (in series allows me to run only one line into the system from outside)
Midnight classic MPPT 250 charge controller
2 UPG 12v 250 amp batteries in series (24 volts)
magnum RD1824 inverter
My questions:
1: do I have any big mismatch?
2: I understand that in series it is best to use diodes, what should I use and where do I get them?
3: With one line coming into the charge controller I can use one disconnect. Any suggestions on what I should use?
4. I plan on running 3 or 4 lines to various places for back-up needs and the add on room. Is it okay to simply run the line from the inverter to a panel with four circuit breakers and then distribute from there
My questions:
I like to tinker... 5 and a half running motorcycles and a pile O'parts
-Rodger-
-Rodger-
rcmatt007 said:I have been thinking of adding a back up system to run a few things in case of an outage, but also wiring it into an small "add on room" to provide some heating and cooling so the system will not be sitting there doing nothing. In Oklahoma we get a lot of sun, but have weather related outages
My questions:
If you used AGM batteries the charging rate corresponding to the full panel power would be OK.
2. You do not need blocking diodes when using a CC. And bypass diodes will already be built into the panels. So, no.
3. No suggestion. But make sure that it is DC rated for the voltage and current and that it can be safely opened with current flowing.
4. Yes, in principle. Will this be subject to a building permit and inspection? If not, it would be a good idea to have a local electrician check your plans and your work if possible.
SMA SB 3000, old BP panels. -
thanks for the reply.
I was looking at 4 panels because they come in a four pack. I figured 265 w panels were more cost efficient than smaller 100 w panels. Would it be best then to use only 2 panels?
I suppose I could add more batteries but yikes $$$$
Any other suggestions on how I might configure this? Maybe I was going for over kill-LOL
What I was planning was something big enough to run a full size refrigerator when needed. Or run the fan part of a NG heater (we are in the country and ice storms take out power) and when not needed for back up, a window AC unit or baseboard heater for the add-on room ( about 120 square feet).
What I was looking to do was build something that could stay under $4-5000. I see now that the store is in Flagstaff and we are out there a couple of times a year visiting familtI like to tinker... 5 and a half running motorcycles and a pile O'parts
-Rodger- -
Not sure why you would go with that charge controller. Would think the midnite 150 or 200 would be a better fit and cheaper. But does depend on certain other factors. Possible future expansion of the series string.
And does not even need to be the midnite line. All depends on what you need/ want.
I particularly like morningstar controllers, but they do have less bells and whistles compared to midnite.
___Edit______
Forgot to mention if funds are real tight I may recommend going with a less expensive mppt controller
And getting a sine wave inverter. Either way funds tight or not sine wave is something to think about
am trying to figure out how best to do this. You are right in that the CC is too big. It did not appear the prices were much less for smaller ones. When I looked in the store for this site, all their prebuilt systems were larger and more expensive than I wanted to go. Maybe it would best to ask them to size something for what I want to do. As I mentioned I go through Flagstaff once or twice a year and so could actually pick up what I need. When I looked at other websites, it was the shipping that made this way too expensiveI like to tinker... 5 and a half running motorcycles and a pile O'parts
-Rodger- -
The midnite 250v is not any bigger it just accepts a higher input voltage. The ONLY reason to go with it is if you needed higher inout voltage, The maximum output of the 250 is actually lower then both the 150 and 200. 150 having the highest output
good to know, thanksI like to tinker... 5 and a half running motorcycles and a pile O'parts
-Rodger- -
I am finding all the tutorials on this site incredibly useful! It looks like this would be a lot more manageable thinking 48 volts not 24. Also, it looks like I could get made in USA panels from the store in flagstaff (I drive through there at least once a year) and not be killed with shipping as well as picking up better batteries.I like to tinker... 5 and a half running motorcycles and a pile O'parts
-Rodger- -
My old solar system was similar but smaller. Year round I used it to run a chest freezer and during the summer I used it to run a window AC unit... It provided some power for power outages and by using if to run some things year round I was able to half way justify the expense of building it.
48v Rolls 6CS 27P
That may not be "too much" solar if he has a bunch of base loads. I myself have "considerably more" solar than I would need for my battery bank if you just looked it at face value. But in reality I have a constant 1.0kw (AC) load 24/7 and an additional 2.0ish kwn in the daytime when the AC is running so the additional/extra solar panels are needed to take that into consideration.Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html
- 228 Forum & Website
- 618 Discussion Forums/Café
