what size wire do I need
oadkins
oadkins Registered Users Posts: 19 ✭✭
I have 14 100 watt panels what size wire do I need from charge controller to 800 amp hour battery bank
    BB. Super Moderators, Administrators Posts: 33,613 admin
    What is the Vmp/Imp ratings of the panels (assume Vmp~17.5 volts?).
    What is the voltage rating of the battery bank (12/24/48volts)?
    How far do you want to run the wires from the array to the battery shed/charge controller?
    Roughly, were will the system be installed (nearest major city)?
  • oadkins
    12 volt system 10 feet from controller to battery bank
    Do you have a choice of charge controller (I.e., 60 amp PWM, 80 amp Outback MPPT, etc.)?
