How to wire a Grundos SQflex pump to a Heart (trace) charger/inverter 220volt AC single leg output
mrleemus1
Registered Users Posts: 28 ✭✭
i recently acquired a HEART (trace) inverter/charger it is a 24 volt, 3K unit. The AC output is 220v single leg. Can i wire it to the SQflex pump directly without using a the CU-310 control box which has failed.
This thread may be of some help. Maybe Dave will see your post.
http://forum.solar-electric.com/discussion/343845/cu200-sqflex-grundfos-controler
Heart is a Trace ? I do not think so... Get the model number off the pump please!"we go where power lines don't" Sierra Nevada mountain area
Dave -- thanks for your response. The pump is a Grundfos model MFS3 with a product number 96275334 and the inverter/charger is HEART INTERFACE 81-2807-24, serial number 53846, date 3592. The inverter looks pretty much identical to the Xantrax Freedom 21 series.
Lee
Looks like a good match if the inverter works. Heart and Trace were completely different companies in the 90's. When I worked in marine electronics, Trace would last over 3 years in a nasty hot humid salt air environment. Heart would start corroding in a year.
Trace became Xantrex and were bought by Schneider electric 5 years or so ago."we go where power lines don't" Sierra Nevada mountain area
the inverter has been in storage for almost all its life. It looks new. I hooked it up to a 24 volt battery bank - and the inverter output is 224 volts AC showing on the multimeter.
that 220 volts is on one one leg. It appears grundfos MFS3 has 3 wires -- two 120 volt hot legs and a ground i assume. How would i wire it for one 220 volt ac hot leg and a ground?
SQ Flex only needs 90-230V AC (and anything in between) to run. You just wire the hot leg up to either of the hot legs on the pump and put the other one to the neutral. Ground goes to the ground.
Good luck. -
Hey Ron,
How is life in the Lone Star? I have been looking for a smaller version of the goulds aquarar for some of my folks. Specifically, have you seen anything in the 240V 1/4 to 1/2 HP that has the soft start packaged with the "surface" pump? A home water system 35 -55 psi?"we go where power lines don't" Sierra Nevada mountain area
- 231 Forum & Website
