Angle vs Shade
JBlackham
Registered Users Posts: 1 ✭
What is worse for a solar panel . A bad angle or shading?
I have always wondered this and I think its shading. As a bad angle still gets the sunlight. Can someone please answer this?
Shade is worse. I don't even bother changing the vertical angle any more. It's set for winter optimum and summer has so much sun it seems to make little if any difference. YMMV. Being a little over paneled can also help with reducing the concern about exact angles. Panels are cheap enough to do that these days.Northern NM, 624 watts PV, The Kid CC, GC-2 batteries @ 24 VDC, Outback VFX3524M
Partial shading of a panel in bright sunlight is probably the worst because that is the circumstance that burns out the bypass diodes.JBlackham said:What is worse for a solar panel . A bad angle or shading?
