Help me understand where my utility power is going (Wishbone)
BB.
Super Moderators, Administrators Posts: 33,725 admin
This discussion was created from comments split from: New forum software is live - report any errors, bugs, or issues here..
After noticing. That turning off my power strips when not in use, unplugging my 220v stove and only using 110v hot plate, reducing my (well) water usage, a b d calling APS. To report - meter not reducing my KWHs- my USAGE KWHS are increasing. HELP PLEASE. I am monotoring start usage and end usage. Does aps increase meter usage to cover losses from mother nature ?
I watched my aps meter and after 2 hours of watering the aps meter showed 18 kwhs usage. Suggestions?
You might want to look at a whole house monitor like this one:
http://www.theenergydetective.com/
You can get ones with several current transformers to put on different branch circuits and figure out what is using most of your power.
And, quickly, you can use a simple Current Clamp Meter (like this one from Sears) to measure AC and DC current... Measure each branch circuit and figure out where the current is going.
Amps * Volts = VA (not Watts technically, this equation may over estimate power/Watts usage a bit).
You could also look at Brultech. They have one that will monitor 32 circuits, and you can get a package deal with two different groupings of CTs. They also have a good website for help and ideas.
http://www.brultech.com/
