Upgraded Solar System
Zakarume
Solar Expert Posts: 143 ✭✭
I just upgraded my System with another 250 more watts and another Midnite Kid. Do i need to add another shunt and Whizbang Jr to this new Kid?
1460 Watts Solar @24v. 675 AH Battery Bank using 12 6v Trojan T-105. 1 Midnite Classic 150. 1500 Watt 24v Samlex Pure Sine Inverter
Hi Zak..,
NO, one Shunt with one WBjr will show all of the current going into and from the battery.
VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Ok i was just wondering. Because i will be adding up to 750 more watts and splitting the Solar into 2 arrays. 960 watts on 1st Array and 2nd eventually 1000 watts1460 Watts Solar @24v. 675 AH Battery Bank using 12 6v Trojan T-105. 1 Midnite Classic 150. 1500 Watt 24v Samlex Pure Sine Inverter
Yes, have run a single Shunt on a system with one MidNite Classic, and one OB MX-60, each charging the same battery (and, yes, separate PV arrays), and the WB reports to the Classic the total battery charging current form each of the different brand CCs. The Classic goes to Float at the correct total EA that is set. Just need to carefully adjust the settings in the MX-60, to try to get it to cooperate without direct communication.
Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
