Inserting fuse holders in Outback PSPV
I'm having trouble inserting fuse holders into my Outback PSPV combiner box. The fuse holders are "Bussmann 13/32" x 1-1/2" 10x38 CHM1D". The mounting bracket in the PSPV and the back of the holder match almost perfectly. They fit together but won't latch. There's a red slider latching mechanism on the holder. When I slide the latch on the holder, it pushes the holder out and off. Seems like the PSPV bracket needs to be bigger so the latch won't be needed, or I have a mismatch between the holder and PSPV.
Any suggestions?
Any suggestions?
Re: Inserting fuse holders in Outback PSPV
flat ..
This has gotten no replies, and you may have found a solution. I know nothing specifically, as use Breakers in my PSPV's, but,
Have you tried asking on the OutBack Forum ??
http://www.outbackpower.com/forum/
You may have called OB, which may be the best approach. Good Luck VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
- 231 Forum & Website
