recharge volts on xw 60-150 cc setup
just starting
Registered Users Posts: 235 ✭✭✭
On my xw 60 -150 I have it set to restart bulk charge at 25.3 volts is this to high
200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
Hi juststarting,
Welcome back to the Forum.
This re-charge as Schneider calls it, begins a new charge cycle on a given day, some other Charge Controllers (CCs) call this ReBulk.
It is generally of limited use in off-grid systems -- although, perhaps if one had a large, intermittent load, like a well pump, or similar, this function might do some good.
Your choice of voltage is not a bad way to start, and try to see how this is working.
This function will do little in the way of trying to maximize the State Of Charge (SOC) as the sun is setting, unless it was triggered by a larger load in mid-afternoon, and the CC was in Float. Later into the afternoon, when the sun is fading, there is so little additional PV power available to do any meaningful battery re-charging. If one has other sources of Renewable Energy like wind, or hydro, Re-charge could be more useful.
Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
