Adding additional panels
BJ_OR
Registered Users Posts: 11 ✭✭
Sorry if this has been covered before but ..
Im adding what I plan to be 600 watts 12v panels to my Rv that already came with 2 100 watt panels wired to a old pwm controller 12 years or more old
Can i just leave them in place Add my 6 -100 watt panels =600watts ...wired 2 ea in series then parallel to a mppt controller Will the old system interfere with the new one? What are my options as I know I cant put the old panels in with the new ones (mismatched)
Yes, you can do what you ask... Old panels+old controller wired directly to battery/battery bus... And new panels+new controller directly to battery bus (fuse/breaker in + lead for each controller to battery bus).
- 600 Watts * 0.77 panel+controller derating * 1/14.5 volts charging = 31.9 amps amps typical maximuim
You can mix/match panels behind a single new MPPT controller--If the Imp and/or Vmp is "close" or within 10% maximum difference. Typically "12 volt" panels have Vmp~18 volts + 0.5 volts--So you can put the two old panel in series, and then put them with the rest of the panels in parallel (2 new panels in series, then 4 total parallel strings). The size of the controller should be (minimum):- 800 Watts * 0.77 panel+controller derating * 1/14.5 volts charging = 42.5 amps amps typical maximum
Get 4x ~200 Watt panels in parallel (Vmp~30 volts) behind one MPPT controller--And you are good to go (again, check price delivered to your front door).
Thanks for the reply I got a deal on the 12 volt panels 100 watts for a little over a hundred ea .. And they fit the space I have perfectly so that's set. And it looks like the existing panels won't go to waste!
thanks I'm new to this and how all the pieces interact with ea other. Now to pick my controller ( thanks for the info) and get my Labor Day week work planned !
