Combiner box FUSE question...(???)
cupcake
Solar Expert Posts: 254 ✭✭✭
Hi Pals -- cupcake here again:
quick question - what are the little 'midget fuses' in the combiner box classified as??
Im talkin about the little ones with the dimesions of:
- 1 1/2” x 13/32” (10mm x 38mm) dimensions
~1.5Kw PV in parallel
Morningstar MPPT-60 controllers (2) in parallel
3 Trojan tr-1275's in parallel 450ah total
Samlex 2,000 watt 12-volt inverter hardwired
Hi cupcake.
These are a "standard" Combiner Fuse:
http://www.solar-electric.com/installation-parts-and-equipment/midnite/cipr1/stfubr1/mnatm.html
They fit the MidNite Combiner Fuse Holder, and, quite possibly others.
FWIW, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Hi cupcake.
FWIW, Vic
Are these sold in stores anywhere like HomeDepot/Lowes etc??
Thanxxx~1.5Kw PV in parallel
Samlex 2,000 watt 12-volt inverter hardwired -
Would be very surprised if any Big Box retailer would carry them.
It is possible that some Wholesale Electrical supply house MIGHT stock them.
AND, if you are ordering them on-line, be careful that you get a Cartridge fuse -- there are some Auto-type Blade fuses under the "ATM" banner. Sometimes the ATM Cartridge fuse is referred as ' ATM1 '.
N AZ Wind & Sun fills orders rapidly, often with same-day shipping ... they may even be able to do US Mail (if your desert location is in the USA).
Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
