Trace DR charger settings
706jim
706jim Solar Expert Posts: 527 ✭✭✭✭
Can't find the manual from my old (1995) Trace DR1524 inverter/charger.
There are two settings: Equalize 1 and Equalize 2.
Does anyone remember what voltages these two settings might generate?
(Unit has a 35 amp charger)
Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
    BB. Super Moderators, Administrators Posts: 33,734 admin
    Does this link work for you?
    http://www.manualslib.com/manual/195381/Xantrex-Dr1512w.html?page=61#manual
    Should be to page 3-5 of the manual.
    The defaults appear to be:
    Bulk/Equalize 15.0 volts for #0 (Eq #1)
    Bulk/Equalize 15.5 volts for #1 (Eq #2)
  • 706jim
    Thanks Bill. This online manual is more detailed than the printed one I have (had?). Of interest is the reduction in surge watts from 4400 to 3500 for the DR1524 model inverter. The section on charging and equalization is far more detailed than the older manual.
    I can't say enough good about this 20 year old unit which continues to operate flawlessly at my island summer camp.
