GVFX Inverters and generator type(s) that will work
westbranch
Solar Expert Posts: 5,183 ✭✭✭✭
I am looking at a pair of older OB 2524 inverters for system expansion. In discussions with the seller he mentioned that they might NOT be usable as, as far as he remembers, they, GVFX's, being grid tie models, did/(will not work with generators to charge batteries.
I followed the discussion about Generator Support and remember that there are several users of GVFX models that did not mention having any problems AFAICR....
Does anyone that uses a GVFX with an INVERTER GENERATOR have issues with the charging circuitry?
Have a gfx1424 and eu3000. Only had to use the gen once since we have an abundance of sun here. Seemed to work fine although it did take it quite a while.
Quite a while to do what?
SMA SB 3000, old BP panels. -
I have a GFX 1312 and it works great with a Honda eu2000, so I would not anticipate a issue with a Inverter Generator.
