RV Mobile Home Install- 1st attempt
Ritmosdapaz
Registered Users Posts: 2
First of all, many congratulations for the forum and to all the community that integrates this forum with valuable knowledge!
Have learnt a lot of stuff just in a couple of days.
However, with so many information in little time - and my poor english - I can say afterall that I feel brain foggy
So I would appreciate your help concerning my proper case and obviously I hope to learn more and more
I have an old Mercedes Bus which I made in RV Mobile Home... With lots of space in the roof I would like to be self-sustainable and as you usually say 'dry camping' (without conecting to grid)
Since my consumptions are not very critical was thinking about beginning with:
3x 255W 24V Panels
1x 30A E tracer MPPT charge controller
Lead Acid True DeepCycle Batteries?!
1 - First doubt: 12V or 24V Solar panels? 24V are cheaper. And will let me grow my system later till 1.5K for example. But for example my water pump and lights are 12V. Is there any problem? Can I 'take' 12V from a 24V battery bank? I mean, can I feed my 12v pump for example from a 24v system?
2 - Batteries: Depending on the 12V or 24V system, what do you advice? 2 x 12V? 4 x 6V? I was thinking of 4 x famous T105 Trojan ones...
3 - I have heard here about ''battery balancing''. Well, this is completely new to me
How can I ensure that I dont make mistakes connecting my batteries? Even after checking the smartgauge schemes (method 4 seems more stable) I didnt get the idea of this method on how to achieve 24V with 6V models...
Thank you very much for the help and sorry for my poor knowledge
Wake up for solar world just yesterday eheh
Thank you!
3x 255W 24V Panels
Thank you!
Here is a video i done on Youtube about my solar install https://www.youtube.com/watch?v=VBlxETpKpDw1460 Watts Solar @24v. 675 AH Battery Bank using 12 6v Trojan T-105. 1 Midnite Classic 150. 1500 Watt 24v Samlex Pure Sine Inverter
Thank you for replying! Well, nice video and set up but for me it still hard to replicate it because I live in europe and this kind of gear is hard to find... Only trojan batteries are reasonable available...
Do you have a diagram showing the way to parellel & Series 4 x 6V batteries in order to make 24V? And how to draw out one 12V wire from the bank? -
This might help for wiring batteries in series and parallel https://www.youtube.com/watch?v=VYhH6-hcu8U1460 Watts Solar @24v. 675 AH Battery Bank using 12 6v Trojan T-105. 1 Midnite Classic 150. 1500 Watt 24v Samlex Pure Sine Inverter
Theis web site will tell you all about connecting batteries with diagrams. http://www.smartgauge.co.uk/batt_con.html
- 230 Forum & Website
