Highly Programmable Controller
SenorPower
Registered Users Posts: 4
I'm working on a project where I need to use a non standard number of cells. I am hoping someone could tell me what are some of the most highly customizable small charge controllers. I'm working with one 240 watt panel and I would like the battery voltage to be around 36 volts.
Welcome. I am not sure how 'custom' your needs are but if the project will not use more panels later on, I would look at the MidNIte KID , handles 30A and very programmable. If that is not enough them look at the MidNite Classic www.MidNitesolar.com
hth
It will always be the one panel. Those are quite a bit bigger than I need.
what are the panel specs?
Max Voltage: 43.7 V
Max Current: 5.51 A
Open Circuit Voltage: 52.4 V
Short Circuit Current: 5.85 A -
that panel may not be enough to fully charge a 36V battery. A 12 V need 17-18V to get fully charged... so a 36V battery will need ~ 51V to 54V.
Here is a link to some info on batteries and scroll down to charging http://www.solar-electric.com/deep-cycle-battery-faq.html/#Battery%20Charging
Sounds like AGM or Gel... what Amp hr rating do they have?
- 651 Solar Water Pumping
- 622 Energy Use & Conservation
- 608 Discussion Forums/Café
