Panels of different size?
BoFuller
Solar Expert Posts: 187 ✭✭✭
3 years ago I bought 12 Kyocera 235GX panels for my off grid cabin. It took way longer to get through County regulations than I anticipated, so I used 3 of the panels on my travel trailer for the last 3 yrs. now I'm ready to put the 12 panels on the roof of the cabin but I want to keep 3 panels on the trailer too. Can I buy 3 new 255 panels and use them as one of the four groups of 3 on my cabin roof or should I put the 255s on the trailer and make all the ones on the house the same (235)?
12 Kyocera 235 panels, 3 Gyll LiFePO4 batteries (previously 16 Trojan L16 RE-B batteries), Outback 3600W 48V system, Generac 11K propane backup generator, NW AZ, off grid, 6,000 ft (system installed in April 2015)
New system will be the 12 panels, 16 L 16RE and an Outback 364812 Kyocera 235 panels, 3 Gyll LiFePO4 batteries (previously 16 Trojan L16 RE-B batteries), Outback 3600W 48V system, Generac 11K propane backup generator, NW AZ, off grid, 6,000 ft (system installed in April 2015)
I would swap out the 3 on the RV and keep the old ones together, but the 3 new ones would likely work if the Vmp is close, but you would probably lose some of their out put as the lower ones will override the new ones.
The rule of thumb is that when putting different types of panels in parallel into a single MPPT input the Vmp values of they two sets of panes need to be within 5% of each other.
For a series connection of mismatched panels the Imp values need to be within 5%.SMA SB 3000, old BP panels. -
Thanks all. I picked up three Kyocera 255s that I will put on the trailer tomorrow, and then put all 12 of the 235s on the house.12 Kyocera 235 panels, 3 Gyll LiFePO4 batteries (previously 16 Trojan L16 RE-B batteries), Outback 3600W 48V system, Generac 11K propane backup generator, NW AZ, off grid, 6,000 ft (system installed in April 2015)
- 611 Discussion Forums/Café
