Trace Batteries
hemmjo
Solar Expert Posts: 94 ✭✭
We picked up 4 Trace T-235 Platinum Batteries and 4 Solar World Panels the other day in Santiago, Dominican Republic. Either I was not able to get them to understand what I wanted in regard to the charging specifications or they did not know. "Just hook them up, good batteries, they will work fine"
I can not find details for them online, does anyone have any details on in regard to charging values for these?
Thanks,
John
Thanks,
John
Two systems in the Dominican Republic http://villagemountainmission.org/
installed Feb 2014 at 19.796189° -70.893594°, Classic 150 + WBJR, KISAE SW1210, MN Battery Monitor, IOTA DLS 55/IQ4, 4- Solar World 275w, 4-6v x 225ah Trace Batteries
installed Feb 2015 at 19.795733° -70.893372°, same components as above
Honda PowerMate PC0497000, 7000/8750w generator - powers the well and chargers maybe once a week
Doesn't Trace have Website.?
It appears to be a company out of the Dominican Republic (or nearby)...Trace International es la Compañía Líder en ventas y servicios de Inversores y Baterías “Trace” en República Dominicana, con una estructura a nivel Nacional conformada por diez sucursales en todo el Pais. Trace International is the leader in sales and services Inverters & Batteries "Trace" in the Dominican Republic, with a national framework consists of ten branches across the Country. www.traceinternational.com
Website(s) do not go anywhere useful at the moment.
Still working on this project. I discovered some information on page 60 of the Classic owners manual. Titled "Battery voltage and time settings", it contains charging voltages and times for the various charge stages for a variety of battery types.
The matrix shows AGM, sealed 1 & 2, Gel, Flooded 1, 2, & 3 and other. The values shown are Absorb, Float, & Equalize voltage, Absorb min/max time, EQ time & EQ interval in days. For flooded the values are;
1-14.6, 13.5, 15.3, 30/120, 28
2-14.7, 13.5, 15.4, 30/120, 28
3-15.5, 13.4, 16.0, 30/180, 14
Does this show me that there are basically 3 types of flooded batteries? I was able to get someone to take the page to Trace in Santiago. They said to use the values for flooded 2 so I am starting with that.
The values listed in this matrix for Flooded 3 are close to those on the Interstate instructions for the GC2 batteries we have on another installation, but not exact.
JohnTwo systems in the Dominican Republic http://villagemountainmission.org/
