Bad charge controller?
FirefliesNfrogs
Registered Users Posts: 2
Hello, this is my first post and I am looking for help. I had recently bought the 100 W solar panel kit on Amazon. It came with a charge controller. I had purchased 2. 6V Duracell golf cart batteries. During the daytime my charge controller says it is charging about 12.5 V and my batteries eventually charge up to 13 V. But after the sun goes down my batteries charge goes down to 12.5, 12.3 V. I do not have my inverter hooked up to my battery bank. I am very interested in solar panels and help to make a Solar battery bank. I just cannot understand why my batteries are not holding a charge. My batteries are new.
Re: Bad charge controller?
Welcome to the forum FFNF!
Ok... Guessing that you might have gotten the Renogy 100 watt panel + 30 amp charge controller. The panel should be fine. The rated current should be around:Renogy 100W Monocrystalline Solar Panel
Maximum Power: 100W
Optimum Operating Voltage (Vmp): 18.9V
Optimum Operating Current (Imp): 5.29A
Don't know anything about the charge controller--But lets assume it is working.
Next, if these are 6 volt ~ 200 AH lead acid batteries. Lets call 12.3 volts about 1/2 charge (for round numbers).
This is winter, using the SolarElectricHandbook for Tulsa OK, fixed array:
[h=3]Tulsa
Average Solar Insolation figures[/h] Measured in kWh/m2/day onto a solar panel set at a 54° angle (from Vertical):
Jan
Feb
Mar
Apr
May
Jun
3.61
4.01
4.74
5.20
5.22
5.37
Jul
Aug
Sep
Oct
Nov
Dec
5.84
5.62
5.28
4.75
3.73
3.36
With a PWM controller the maximum charging current Imp~5.29 Amps. With 4.01 hours of sun average for February:
5.29 amps * 4.01 hours of sun = 21.2 AH of current per day
The battery:
200 AH * 50% = 100 AH
100 AH / 21.2 AH per day = 4.71 days of average sun for February
The 200 AH battery bank with ~5 amps of charging current is about the minimum size solar panel we would recommend for charging a lead acid battery. That is OK for weekend/seasonal usage... For daily usage, a 10% to 13%+ solar array would be nice.
If you would like to learn more about your system and how it is operating, you might want to look at getting a DC Current Clamp Digital Multi Meter, such as this one from Sears (pretty inexpensive and "good enough" for our needs).
You should also get a decent Glass Hydrometer to measure the specific gravity of your battery bank (assuming flooded cell). If you want a really nice Hydrometer, take a look at this one.
Read about batteries... They are the "critical part" of your system. If you leave it set at less than ~75% state of charge, it will sulfate faster (and could be dead within 6 months).
http://www.windsun.com/Batteries/Battery_FAQ.htm
http://www.batteryfaq.org/
http://batteryuniversity.com/
Electrically speaking, you want to see the charging voltage of the battery to be held at 2-6 hours or so at around 14.4 to 14.8 volts to be fully charged.
Re: Bad charge controller?FirefliesNfrogs wrote: »Hello, this is my first post and I am looking for help. I had recently bought the 100 W solar panel kit on Amazon. It came with a charge controller. I had purchased 2. 6V Duracell golf cart batteries. During the daytime my charge controller says it is charging about 12.5 V and my batteries eventually charge up to 13 V. But after the sun goes down my batteries charge goes down to 12.5, 12.3 V. I do not have my inverter hooked up to my battery bank. I am very interested in solar panels and help to make a Solar battery bank. I just cannot understand why my batteries are not holding a charge. My batteries are new.
I used golf cart batteries for years. (Mine were set up for 24 volts, so compare half of my readings here).
I would float the batteries at 27.0 volts (or 13.5 for your case) and a few hours after the sun went down, the voltage would drop to about 25.0 (or 12.5 in your case) even if there was zero load on them.
I don't think there's anything wrong with your batteries although the charge controller could probably have a higher cutoff point if it is adjustable.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year. -
Thank you all for the help.
- 234 Forum & Website
