Changed to new batteries. Charging parameter questions.
castilloj
Solar Expert Posts: 208 ✭
Hi everyone, i have a 24 v outback system and i run big generator from 8 am till noon
Then 6 pm till 11 pm within those hours i run power from my batteries.
The batteries i just installed are
4 trojan L16H 425 ah at 20 hours
357 ah at 5 hours
What should the charging parameters be? Also could i combine with my old L16 RE 325 ah at 20 hours?
357 ah at 5 hours
Re: Changed to new batteries. Charging parameter questions.
see the middle of the page... http://www.trojanbattery.com/pdf/datasheets/L16HAC_Trojan_Data_Sheets.pdf
hth
