Honda to charge batteries
Arkansasoffgrid
Solar Expert Posts: 117 ✭✭
All my equip is listed in my signature, but my manuals are 6+ hrs away. How do I use the honda to charge batts, & power home? I have it wired according to drawing/print. It's a ?? of what switches are in what position?
8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator.
Re: Honda to charge batteries
No it's a question of programming the Magnum inverter-charger to not exceed the output capacity of the generator and yet still supply enough current to charge the batteries (which aren't specified in your signature).
BTW you can look up the manuals on-line, which makes things easy:
MS4448PAE manual http://www.solar-electric.com/lib/wind-sun/Magnum-MS-PAE-Manual.pdf -
Thanks for the link, was able to get it charging within 30 minutes. Had to reduce charging to 30% for the Honda not to overload. 8-6V GC2 batts.8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator.
